2000 Boxster OEM Twist Rims 17"
Porsche OEM 17'' 2000 Boxster Twist rims & Bridgestone tires,205/50 ZR17(frnt),255/40 ZR17
Has anyone tried these on a 944/951? I dont know the offset of the rims, if anyone can help me determine if this rim/tire combination would fit my car I would appreciate it. I would rather not use spacers.
Thanks,
Thanks,
You would be best off with something slightly wider on the front. The large difference between the front and rear will cause the car to understeer a lot. I would go with some 225 width tires on the front for a more neutral setup.
