PS Pump Removal (pics)+ Rebuild **New Problem**
Old 01-20-2003, 06:07 PM
Conor
Conor's Avatar
Post PS Pump Removal (pics)+ Rebuild **New Problem**
**See Bottom Post For New Issue**
I am right in the middle of trying to remove my ps pump and I cannot get the darn thing off. After I got it to swing freely I removed a nut from the front end and a bolt and thick metal sleeve from the other. It looks like there is a sleeve on the other end that should come off but won't. I put arrows to that on some of the pics. Anyone know how to get the pump off, or get that sleeve off? Any help is appreciated, I need to go to school tomorrow!
Conor
<img src="http://members.rennlist.com/cfgriffin/pspump1.jpg" alt=" - " />
<img src="http://members.rennlist.com/cfgriffin/pspump2.jpg" alt=" - " />
<img src="http://members.rennlist.com/cfgriffin/pspump3.jpg" alt=" - " />
<img src="http://members.rennlist.com/cfgriffin/pspump4.jpg" alt=" - " />
Old 01-20-2003, 07:09 PM
Mike B
Done With Sidepatch
Mike B's Avatar
Post
There is another nut at the back end of the pump...Did you take that off...
Old 01-20-2003, 07:33 PM
Conor
Conor's Avatar
Post
I believe so, but it was a bolt, the one farthest to the left in the last pic.
Old 01-20-2003, 08:10 PM
Mike B
Done With Sidepatch
Mike B's Avatar
Post
I think I see your problem...The sleeve/spacer you have the arrows pointed to is on the wrong side of the mounting bracket...
I believe that should be on the other side (towards the rear) of the mounting bracket...You should be able to get a screwdriver or flat punch in behind the spacer and knock it out...That opening where the spacer is now is for a nut/washer...Once you get the sleeve/spacer off the bolt you should be home free...
Old 01-20-2003, 08:12 PM
zakk
zakk's Avatar
Post
Speaking of power steering pumps, anyone have the part numbers or specifications for the bolt/shaft/nut in the first picture you're pointing to? My car seems to be a bit challenged in this area . The bolt directly across from it would be nice to know too. Thanks in advance.
Old 01-20-2003, 08:20 PM
Rich Sandor
Rich Sandor's Avatar
Post
I would spray a ****load of wd40 or some other grease all over the end spacer, let it sit for a while, spray some more on, and then use some pliers or a crescent to try to screw it off the last bit of thread, and then pull it off.
Old 01-20-2003, 08:33 PM
Conor
Conor's Avatar
Post
Thanks, I feel more comfortable whacking at something I know is supposed to come off! The spacer isn't even threaded so I should be able to get it outta there.
Old 01-20-2003, 09:35 PM
Conor
Conor's Avatar
Post
I got it off! It took a couple good hits from a hammer onto a screw driver, but it's off. Thanks again, now I can start re-sealing it.
BTW zakk, when I get on my other computer I will check the PET for you and try and get you the numbers.
Old 01-20-2003, 10:32 PM
Mike B
Done With Sidepatch
Mike B's Avatar
Post
Glad to hear it...Keep us posted!
<img border="0" alt="[thumbsup]" title="" src="graemlins/bigok.gif" />
Old 01-20-2003, 11:15 PM
Conor
Conor's Avatar
Post
I seem to have run into another snag. I am now trying to get the pump all apart to install the new seals, and I can't seem to get this clip/ring thing off of the end of the long part the pulley is attached to. It seems to be the only thing keeping me from getting that piece out. I am referring to the ring with the gap just above the gears. Any ideas?
Thanks,
Conor
<img src="http://members.rennlist.com/cfgriffin/pumptop.jpg" alt=" - " />
Old 01-20-2003, 11:22 PM
sharky47
Set to Full-Auto
sharky47's Avatar
Post
I have a question along these line, I have an '87 944S and the forward PS pump mount is cracked and broken where the bolt goes through. Can I replace this mount or do I have to weld it?. Anyway, any help with this would be GREATLY appreciated.
Old 01-20-2003, 11:24 PM
mideastmafia
mideastmafia's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by Conor:
<strong>**See Bottom Post For New Issue**
</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">why do u need power steering to go to school?
SHAUN
Old 01-20-2003, 11:26 PM
Conor
Conor's Avatar
Post
Actually, I had forgotten that I have school off tomorrow. But, I thought it was bad for the power rack to run with no fluid, and I drained all of the fluid when I took the pump off.
Old 01-20-2003, 11:43 PM
Conor
Conor's Avatar
Post
Here is what I found for part numbers: <img src="http://members.rennlist.com/cfgriffin/partnum.jpg" alt=" - " />
The top two are from the back of the pump. In the PET the front bolt/nut is shown as part of the pump, so there was no separate number.
Conor
Old 01-20-2003, 11:53 PM
MHT
MHT's Avatar
Post
the spacer in the front of the pump was in the correct location, it belongs in front of the bracket. The ring is a snap ring, you will need to expand it to get it off. There are special pliers to do this job but you may be able to get it off with a couple of screwdrivers working agianst each other. Wear eye protection, these things can take off, they are stiff springs.
Quick Reply: PS Pump Removal (pics)+ Rebuild **New Problem**
