Wheel bearing/Ball Joints Question
Not sure on the terminology, but what is the diff between the wheel bearings and ball joints?
My front wheels are acting funny and I want to replace these (depending on which is which). Also, I was told there are inner and outer ball joints? Can someone clarify all this for me, and if possible let me know if there is a website that explains how to change these types of things?
Sorry for the stupid question...I am trying to solve my popping noise coming from the front tire. Also, I was told my E30 needs new wheel bearings...so I want to know the differences between the terms since I'm starting to feel they are the same thing.
Mike
Mike
There are three ball-joints per side in the front suspension of the 944. The primary ball-joint is the attaching point from the control arm (A-arm) to the steering knuckle (spindle). This is the highest wear ball-joint, and can certainly be responsible for your problems. There are also two ball-joints on each side of the steering rack - the outer tie-rod ball-joint being the higher failure unit - and easier and cheaper to replace. The inner tie-rod ball-joint is concealed by the rack boot.
Wheel bearings are completely different, but can cause some of the same drivability problems, and even be diagnosed nearly the same. The wheel bearings ride inside the wheel hub and on the axles, both front and rear.
The general check for all of these is a wiggle test and visual inspection. In many cases of apparent front wheel bearing problems, the hub can be cleaned, repacked, and reinstalled.
Tell us more of your situation and indications - but definitely go out and shake the wheels vigorously to check for play.
Good Luck!
Good Luck!
Lifetime Member
Lifetime Member
Mike,
Skip has it covered, as usual -
The only thing I'd be tempted to add is to suggest you pick up a Haynes repair manual and take a look through the various procedures and photos. Some auto parts stores carry the Haynes, and I'm sure they're available from Amazon, etc. Pretty cheap, and a good way to become familiar with some of the parts and pieces of these cars.
Matt
Matt
I suggest you find a good alignment shop. They shoud be able to diagnose the problem in a couple of minutes.
The good news is that the problem is easily solved and not all that expensive (in terms of Porsche repair costs).
