bouncing tachometer
Old Apr 14, 2009 | 12:28 PM
krazykarl's Avatar
krazykarl
Default bouncing tachometer
I have had an unusual problem with my S2s tachometer since not long after I purchased the car September of last year. When shifting, the tachometer needle will bounce as much as 750 RPM back and forth 2-3 time before settling in. From then on it increases and decreases normally until the next time I shift. If I shift harder and am on the gas it may only bounce once in a range of about 250 RPM. All my other gauges seem to work fine, and I do not here the engine revs bouncing so I am fairly certain it is an instrument issue. I have had my cluster out a couple of times this spring, but as I had the issue beforehand I don't believe I caused it. Any ideas on a cause? Where to troubleshoot?
Old Apr 15, 2009 | 06:03 PM
krazykarl's Avatar
krazykarl
Guess no one has had this problem before...
Old Apr 15, 2009 | 11:40 PM
Daily944's Avatar
Daily944
hey Karl,
I've seen this topic up a couple times over the last few years. Check all your grounds under the dash for starters. I'd also speed sensor on the bell housing, check to make sure it's connected at the plug and still screwed in.
First things that come to mind, you might find more results using the search. Or even check clarks-garage.
Old Apr 16, 2009 | 12:16 AM
krazykarl's Avatar
krazykarl
Grounds under the dash looked good last month when I checked them to troubleshoot the fact my fuel level doesn't go above 3/4ths full. I didn't find much regarding a similar issue when searching, but I'll look up more info on the speed and reference sensors. Thanks for the input.
Old Apr 20, 2009 | 02:39 PM
krazykarl's Avatar
krazykarl
To add a bit more information, the amount of bounce varies quite a bit depending on my shift. If I rev match well and am consistent with my application of power it only bounces a little bit. If I perform a harder shift or I am hardly on the gas it can bounce over 1000RPM.
Old Apr 20, 2009 | 03:21 PM
Z-man's Avatar
Z-man
I have that same issue. Had it since I've owned the car since 2001.
No biggie for me, since it will 'settle' down to the real number in a second or two after engaging the next gear.
-Z
Old Apr 20, 2009 | 03:28 PM
krazykarl's Avatar
krazykarl
That's good to know. Guess that it means my transmission isn't due for an impending explosion if yours has been like that for 8 years, thanks.
Old Dec 16, 2010 | 01:21 PM
catfish's Avatar
catfish
Any solution to this? Search gives a bunch of threads with tachs that don't work or stick at certain RPM, but not this problem... My S2 has done this since I got it a few months ago. Not a deal breaker obviously, but annoying. Is this specific to the S2?
7 Porsche Models That Have Aged Like Fine Wine
Old Dec 17, 2010 | 04:38 AM
Eric_Oz_S2's Avatar
Eric_Oz_S2
My tach does the same - I thought that was normal - ie how it works from new??
Old Dec 17, 2010 | 01:14 PM
pettybird's Avatar
pettybird
my '87 S doesn't do it, so it's not a 16V thing. my 89 951 doesn't do it, so it's not an '89 thing.
I watched my tach really carefully on the way to work and back yesterday to be sure, but it doesn't do anything like you're describing. weird!
Old Dec 17, 2010 | 01:32 PM
Excelerate's Avatar
Excelerate
Did you ever solve the fuel level issue? I'm having the same problem and cleaning contacts on the fuel level sender didn't help me. Did you end up having to replace the sender or was it something else?
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
