Transaxle rattle has gotten REALLY loud.
I wish you were closer! I'm West of Washington DC, about 8+ hours North of you. And that assumes the car could go that far!
Thanks a ton for the offer though.
Follow up.
OK, I had the car up and was doing some amateur diagnosis. There is definitely a lot of play in the driveshaft. With the rubber viewport covers off the front of the rear "pumpkin", I could look at the torque tube coupler. First, I was astounded at how clean it was in there! Like a hospital operating room.
The coupler looked good but if I rotated the tires by hand, with the car in 1st gear (not running) the drive shaft clearly had about 1/4 turn off slop before it hit the hard points.
Does that help the diagnosis?
I'm setting up a shop visit but I'd like to be armed with info.
