help! torque specs for front sway bar
I need torque specs for the front sway bar mount bolts, as well as for the end links. I need to get this finished tonight to have transportation in the morning.
Thanks,
Jeff
Thanks,
Jeff
Close when suspension is at full travel, it SHOULD move away with the suspension under load... Did you install the washer and bushing on the underside of the arm?
Yep, forgot about the fact that it is unloaded right now since it is on stands. There is one bushing and washer on bottom, one each on top. My bad - and rework now.
Also, careful not to brake the radiator plug after you are done bleeding the radiator...it is $10 and you cannot find it but from a Porsche parts supplier....I had to use a metric bolt to replace the one I broke.
I used an import plug from Autozone, ordering a new radiator to replace the old one in my car when I re-do the hoses in a week or so after I get back from spring break...
