Tighten top strut nut with koni
How do you tighten the top strut nut to 57ftlbs. With the koni coilovers that have the adjustment tab on top?
The car is on the ground and I am trying to tighten it and it just spins the whole assembly. And I can't figure out anyway to hold the center and still turn the outer main nut.
Crowsfoot is available at any part place... under $20
Thats what I was planning on doing but a socket does not fit on the top half.
It has two flat sides and two rounded sides, a 11mm socket is too small, and a 12mm is too big...
