WTB: 7mm spacers
WTB: 7mm spacers
Looking to buy 7mm spacers. That is all I need to have my BBS RS wheels clear the turbo brakes I just installed on my '86 NA. I read that I can get away with the stock studs for that thickness of the spacer...can somebody else confirm that?
Thanks!
Thanks!
The rule of thumb regarding spacers is to have at least one full turn of the bolt exposed after tighening the nut.
On my Boxster S I can run the 5mm spacers in front w/o any problem but I have to use different bolts for the 15mm on the rears.
The other rule of thumb I have heard is to have 5 complete turns on the nut/bolt. What if the nuts are not opened but closed like the stock ones...I cannot see the bolt in this case?
