high idle - repair thoughts
My 87NA has been idleing around 2300 once warmed up, and I know the classic "first check" is the IAC. The question is, should I just order the hoses to/from the IAC and put them in regardless? I don't want to start opening things up and then be in a position of "without needed parts". I will also be putting in a new radiator and expansion tank over spring break. Thoughts of members are appreciated.
Jeff
Jeff
Throttle linkage/cable appears ok, not sure how many/which vacuum lines to check. PET diagrams aren't necessarily the most helpful for placement. TPS has been replaced in the past.
How does one adjust the TPS? I didn't see anything in clark's garage on adjustment. Also, which vacuum lines are most likely culprits to check?
I hate to say it, but all of them, particularly if they are original. On the TPS, do you hear a tiny click as the TB is fully closed?
For vacuum lines, grab a flathead screwdriver, open the hood, and tighten any clamps on the ends of rubber hoses you can find. I did it as maintenance, fixed my idle from 1200 to 600, and the car performed much better than previously.
BTW, I should clarify. If you close the idle screw all the way and the engine still runs, you got a vacuum leak. Get a can of carburetor cleaner with a straw and shoot it around suspected leaks. If the engine rpm goes up, thats where your vacuum leak is.
