Engine just died on the highway... and then was fine (?!)
Sorry guys, my fault - I genuinely don't get why the TPS may be to blame... and I am pretty new here so I'm probably missing something. Did read it up on clarks and it does say that the TPS can cause all sorts of issues (but not the engine dying one)...
Here's hoping it's as simple as the DME relay.
In my case it was cracked solder joints on the DME board. The fix is fairly straightforward, here's a link to my write-up. Several people have solved similar issues with this solution, hope it helps!
Thanks Greg, lets hope it doesn't get to this. I've replaced the relay, made sure the sensor is connected well and tested the TPS. Now only time will tell whether I need to start soldering the DME... (check this thread in a couple of weeks... on not)
