Steering Wheel feels loose
The steering wheel feels like it's not on the column securely. Do I just pull off the horn pad and tighten up the nut? Or is there another area to tighten?
is it the wheel that's loose? or the column?
yea pull the pad off and tighten the nut sure. quick and simple. if it doesn't work, then u'll have to start looking at the steering shaft ujoint or the rack
If you don't have an airbag, then yes - just yank & tighten. You'll need a massive socket (23/24mm?) w/ a long extension (6-12") to tighten it. I'm not familiar with the airbag wheel process, but it's different.
