FS: Misc parts
PS. I have some stuff for free... you pay shipping.
-Rear brake shields
-Early offset manual rack tie rods (rack ends shot, but the spindle ends feel pretty tight)
-951 flywheel (used)
-951 pressure plate (used)
-Early steel rear control arms (with hubs with long studs) - (prefer pickup for these)
-Rear brake shields
PPS. And I have some stuff for sale - all reasonable offers entertained:
-Rear sway bar (14mm) with all hardware (including eccentric bolt mounts) - 75$
-Front spindles (with washers and pinch nuts) - $40
-Front hubs (with dust caps) - $40
-(Spindles and hubs together - SAVE - $70)
-Steel control arms (pair) - $40
-Rear calipers, with pads (maybe to rebuild, or as cores) - $20
-Front calipers, with pads (maybe to rebuild, or as cores) - $20
-Complete wiring harness (engine/interior/gauge cluster) with fuse blocks (some relays missing) - $40
-Parking brake cables and all actuation hardware (and pads) - $40
(cables may be spoken for)
-Master cylinder - $10
-Brake fluid reservoir - $5
-Power steering universal shaft (joints feel really nice) - $25
-Power steering rack (it's quite clean, but working status unknown) - $25
-Power steering reservoir (no cracks) - $5
-Front sub-frame - $25
-Late sunroof motor (and cable drive mechanism, if you want) - $25
-Rear hatch release motor - $10
-Complete rear wiper assembly (arm, wiper, motor, housing, switch) - $40
An '84. They were not leaking when removed - in fact the master is quite clean - I wonder if it was replaced once upon a time (i.e. not original).
