Hex socket head bolt on S2 starter motor
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Instead of two standard 19mm bolts retaing my 1990 S2 starter motor (as I expected would be the case reading Clark's Garage), I've got one standard 19mm bolt on the RHS , and a hex socket head bolt on the LHS. (It looks like about a 10mm hex key is needed.)
WTF? Is this an S2 thing, or has a non-standard bolt somehow found it's way into my starter motor over the years?
If it _is_ an S2 thing, anyone have any idea what would motivate the change?
Also, if someone could confirm the size of the hex driver required, that would be helpful.
Yup, I have seen the allen bolt on a few different 944's as well. Probably S2's, I don't remember anymore. And yes, it is a 10mm
That allen key is another "thanks lance" for giving us access to his garage.
BTW did you try Rico's yet?
