Interest in "Turbo Cup" style Strut Tower Bar ?
#31
Part of the IN Crowd
Nope, you aren't the only one..................I love mine and am grateful that Jim did that first run.
It's just the typical 944 crowd. Remember, this is the same crowd that thinks a timing belt is too expensive and difficult to deal with so they think it would be no problem and cheaper to invent a low-cost aftermarket timing chain to fix the problem instead.![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
For a living I source fabricated parts. So I know the capabilities of many good fab shops. All I was trying to do was offer a cheaper alternative.
I don't understand the push back. I said I would be in for one at the proposed price. I have far more complex assemblies that I quote everyday for less.
I apologize if I offended anyone. Just thought I would lend a hand.
#32
If you only knew who you were talking about.
#37
Bar is 10mm x 30mm (approx 3/8" x 1 3/16"). There are 4 bends (8" to 2'-6" radius) in the vertical plane w/ 5 straight sections, and 2 bends (3'-6" to 8'-0") in the horizontal plane with 3 straight sections.
I appreciate the offer, and will send a reply by PM.
#38
Remember this a factory motorsport design - they did/do know a little bit about suspension. In addition to the single bar on the 200+ 951 Cups and Club Sports, the factory used triangulated braces and cage tubing out to the shock towers on various race versions of the 911 and 944 chassis - which is significantly stiffer. I am fairly certain all these cars were cornerbalanced quite often.
#39
Can the bends in the horizontal be cut in the flat or are you bending it after it is cut out?
#41
Just an fyi - if you are racing, welding new mounting points unto a race car pretty much bumps you out of stock and street prepped up into GT classes. In which case, you may as well just weld in a full triangulated strut bar setup, not this one.
While I don't dispute that the turbo cup bar definately helps - it is clearly not the pinnacle of engineering from Weissach. They were built as a cost effective upgrade to the low-cost 944 race cars. Once Porsche decided to actually put some effort into it, you can see the huge improvement that resulted in the 968 turbo strut bars - which is the sort of design you should want to spend your money on.
#42
It will take spending an awful lot of your money to get a factory carbon fiber 968 Turbo RS strut tower bar. I am sure it is much lighter, but I am not certain that it offers any additional structural rigidity vs the steel bar.
#43
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#44
I know several 968 owners are scouring the world looking for one of these-I've seen only two in person. With a cab with somewhat stiffened suspension I had three stb's-my last one, a Dynatech, is nla as well-but combined with my Brey Kraus underbrace tighten things up well. Would I drop major $$ if I found the Porsche Motorsport brace-you betcha!
#45
