OT: Worth more than just a smile - and TRUE
Plane Problems
After every flight, pilots complete a gripe sheet which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction. The form is a piece of paper that the pilot completes, and then the mechanics read and correct the problem.
They then respond in writing on the lower half of the form what remedial action was taken and the pilot reviews the gripe sheets before the next flight.
Never let it be said that ground crews and engineers lack a sense of humor. Here are some actual logged maintenance complaints and problems, as submitted by QANTAS pilots, and the solution recorded by maintenance engineers. By the way, Quantas is the only major airline that has never had an accident.
P = The problem logged by the pilot.
S = The solution and action taken by the engineers.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except autoland very rough.
S: Autoland not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 2000 fpm descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with words.
P: Mouse in cockpit.
S: Cat installed.
P: IFF inoperative.
S: Cat installed.
That's been around for a while. Funny non the less. I work in Naval Aviation and saw that about 10 years ago. It resurfaces under a new heading every time. I first saw as Navy maintainers, then it was Air Force, etc. I don't know how it started but it is funny.
What really funny is when you actually SEE one of those in the aircraft's log book!!!!
Here's on I wrote once, and the reply I got.
P: The autopilot does not hold altitude
S: The autopilot was removed.
great solution, hey? damn AMEs.
