how reliable is welding a crankshaft
Old 01-27-2009 | 10:13 PM
fortysixandtwo's Avatar
fortysixandtwo
Yeah, no problems with welding or flame spraying.
Old 01-28-2009 | 09:44 AM
ideola's Avatar
ideola
Former Vendor
Crank welding is done ALL the time here in Detroit. It is a common practice for increasing stroke. Taken to a reputable, competent welder, you should have NO concerns whatsoever, but you should find a specialist who does this type of work every day. There are two such specialist in Detroit, Performance Crankshaft and Crankshaft Craftsmen. If you can't find a local source, I'd be happy to provide contact information. I personally used A.W. Brown at Performance Crankshaft to develop a 2.0L stroker setup.
Old 01-29-2009 | 08:33 PM
Relaxed90's Avatar
Relaxed90
Originally Posted by V2Rocket_aka944
if the weld is anything less than perfect even with a low-power engine like in the mule the stress could destroy it.
lol
Old 01-29-2009 | 09:04 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator - "Tyson"
Originally Posted by Lorax
Go for it. If if fails, you really won't be worse off...
That depends on how fast he's going when it fails.
Old 01-30-2009 | 12:45 AM
lee101315's Avatar
lee101315
Originally Posted by Marcquito
I had the crank welded on my GS-T after the engine blew 2 years ago. Still runs strong. It was also welded properly, of course.
Yes, I did the same on MY gs-t too. I would rather have a crank repaired than to install another crank in my block... just go for it.
Quick Reply: how reliable is welding a crankshaft
