Adjustable M030 rear sway bar -- What setting do you use?
I installed mine last night and used the middle setting. I run aftermarket springs effective rates about (350# front and back). I also have the 30mm hollow front bar.
I figure I'll never really know until my next day at the track. I'd rather be wrong on the understeer side than oversteer.
Start out at the end of the bar. Run a session then come in and set it to the stiffest setting and see if you can notice the difference. Of course you want to test this in an area where there is plenty of safe runnoff and ther is no traffic around you.
Then adjust to suit.
Have fun.
Have fun.
Have fun.
Have fun.
+1 on above advice, the only way to get the feel of the different settings is to mess around with them where it is safe. Good luck, have fun.
You will notice, I started with mine on middle setting and moved to stiffest setting and could kick the rear out on the street without trying very hard. This on a turbo car but on slow corners so mostly off boost. Back onto the middle setting now.
