rear lower shock mounting bolt
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
I'm having trouble getting this off. What are the options? Does it need an impact wrench to loosen it normally?
OK, forget about the lower mounting bolt -- got that off with a bigger bar -- but what about the upper?
There's some plastic moulding obscuring access to it so that an open wrench will fit on, but not a socket.
How are you supposed to torque it if you can't get a socket on it?
That's assuming I can get it off without a socket in the first place.
What is the plastic moulding anyway? Is it something easy to remove from inside the body?
This is on an S2, BTW (although I suspect that doesn't make it any different in this area.)
I don't know what plastic molding you're talking about, but to torque it you can use a crowfoot attachment for your torque wrench.
![](http://www.drillspot.com/pimages/343/34391_300.jpg)
Don't forget to recalculate the proper torque wrench setting, taking into account the added length (about .5"?) of the crowfoot.
http://www.engineersedge.com/manufac...e_wrench_1.htm
Thank you, Makis, you solved my problems... it could have taken me a _long_ time to find that bolt head in the wheel well (kinda covered in caked mud and everything...)
All done... but not exactly the cleanest job! I think I've just spent as much time washing all the road grime off as it took to swap the shocks...
To follow up on this one. When I have had probles pulling the two bolts I have found it easier to take a jack and jack up the rotor until I find the sweet spot where there isn't any force on the top or the bottoms of the bolts then they will just pull out. Just some info.
There is great stuff I use called PB Blaster I always spray bolts down with it before taking them off. Get a can at any Advance, Pep boys, or Napa. Soak the bolt and try it again.
That plastic trim thing is your gas tank. You can torque the the bolt by jamming a box end wrench to the inside, and using a regular torque wrench and socket on the outside. Should me 17mm. As mentioned dont pull the lower bolt without getting the load out, as it could damage it. Also get the lower bolt torqued correctly, the upper isnt quite as important.
