water sloshing sound ??
I notice a water sloshing / moving sound when I rev the throttle at idle. Sounds like its cominf from the heater core area. Is this normal?
Is your engine running a bit hot? Sounds like you might have a bit of air in the coolant system and need to bleed it out.
Regards, ...Scott
Regards, ...Scott
[quote]Originally posted by sh944:
<strong>Is your engine running a bit hot? Sounds like you might have a bit of air in the coolant system and need to bleed it out.
Regards, ...Scott</strong><hr></blockquote>
Yep: It's probably air in the coolant system.
A little air won't cause any overheating issues, but will make that sloshing sound.
Time for a bleeding of the coolant system!
-Z.
-Z.
