Need pic of 83 window relay location SOLVED
I looked behind my center console and I do not have a connector behind there.
I do see a couple of relays hooked up beneath the dash on the right hand side of the DME. What are those?
Appreciate it, looking to solve window problems. All wires are intact. Cleaned switches already. Fuse OK. Maybe it is relay.
***It seems the 83 has two relays, one for each side attached to the dash next to the DME, right above the driver's right knee. I jumped the terminals and both windows work, so I need to order some relays.
