MAP from guru
Whats the difference between the MAP stage 1 and stage 2 from guru. Can u guys tell me your experiance and gains from this kit.
The only difference between them is the stage 2 provides you with a relocated air filter via a custom designed J-pipe that provides much more of a direct shot from filter to tubo inlet - less bends. I think the gains from this are seen mostly in the upper end providing as little intake restriction as possible.
Follow the links on the Guru site for Rennlist discussions about the kit - very helpful.
Oh, . . . and I hope your not pointing that gun at me!
