Paint Folk : where can I order Spies Hecker paint?
That means more like a pint, because with the DuPont you mix 50/50 color and "basemaker" (plus some activator, but not enough to make a difference for the purposes of how much you have to spray). So check your spec sheets and make sure you know how much you end up with that is actually sprayable - it might be a lot more than you think.
Oh....cheap-o HVLP gravity feed gun. Your results will obviously vary if you're using something else.
I did it in 2, partly bc the single stage paint covers so well, partly bc I like a the factory thin paint look and partly bc I didn't buff a lot of it off. Two won't leave much room for error tho.
Interesting that you want to buy quality paint but don't know how much to buy. Just an idea but maybe a practice job to sort of get the hang of it. In any case, be safe.
Bruce
PS... A dog can get sick from this stuff even from 30 yards away.
Bruce
Depends on what you need for full coverage. For a rough idea, I was able to get around the entire car once, including all disassembled pieces, with my base coat of DuPont ChromaPremier metallic base on about a quart.
I used DuPont ChomaPremier because that's what the guys in the shop recommended and knew the most about. And it worked out great, because all the questions I had along the way were answered and answered correctly. You just can't discount the value of finding a good local shop.
That being said, is there some reason you want this specific brand? If I were you, I'd just use whatever you have available locally that's sold someplace that will pay attention to you. There are very few final durability/look differences between all of the high end auto refinishes, but there is a huge difference in prep, process, etc.
Also, don't even think about buying ANYTHING without the spec sheets for the paint and every last other part of the system that is involved. Seriously. You need to read them. The chemists that write them are smart and know how you need to use the **** that they made.
Yeah...figure out your paint volume SPRAYABLE and go from there. I don't know how its coverage will be, but I'm going to guess that a black will cover just about anything pretty well. Assuming 2-3 coats will not only cover, but be sufficient for a good coat according to the spec sheets, I'd probably go with 2 or 3 liters of (ready to spray) paint. But I'd want to talk to someone who has sprayed it before making any decisions like that.
The reason I'm going after that paint is because it's exactly the right amount of gloss I'm looking for. I haven't been able to find the paint specs online, but I'm sure once i find a place that can order it for me, they'll be able get those as well. I guess my best shot is to hit up local paint places?
Spies is owned by DuPont so I would find a local DuPont distributor. They will most likely have either Spies or Standox(sister company). You can also go to www.pc.dupont.com. There you will find tech info and a distributor locator as well. Good luck. Btw, baking is not necessary, makes no difference whatsoever in regards to durability. A booth with bake capability is a production aid, nothing more.
