brake fluid change
Old 06-26-2003, 03:26 PM
IceShark
IceShark's Avatar
Post
LOL, Ok, Gratian.
Then you have the choices outlined above.
I borrowed my Mother's '89 Crown Vic that I find out had never had the brake fluid changed. I came out of the store and noticed this pool of fluid. Brake line rusted from inside out. Good thing I had the car and saw it or she probably would have had a crash.
Old 06-26-2003, 04:13 PM
coolhand
coolhand's Avatar
Post
If you bleed the brakes do you need to bleed the clutch? What i guess i mean is how will you get air into the clutch by just bleeding the brakes?
Old 06-26-2003, 04:21 PM
pete944
pete944's Avatar
Post
You don't need to bleed the clutch if you're only bleeding brakes. You do need to bleed the clutch & brakes if you're changing the fluid out.
Old 06-26-2003, 06:13 PM
Randy_J
Randy_J's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by gratian:
<strong>I do not have here a pressure bleeder, but if someone can explain how it works I can my own one.Is good that you Ice told me the clutch slave problem.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Here's a great site for a home made Power Bleeder <a href="http://www.bmw-m.net/TechProc/bleeder.htm" target="_blank">http://www.bmw-m.net/TechProc/bleeder.htm]</a>
Old 06-26-2003, 08:20 PM
Tremelune
Tremelune's Avatar
Post
^ There it is.
The brakes and the clutch share the same reservoir, so if one leaks, they all do...
I didn't realize you were in Romania--I'd go the Friend method as well in that case. Just make sure you keep the resevoir above the blue hose when you do the clutch slave. I did mine when it got air in the line with a buddy and it came out fine. If you keep air out of there, you'll have a better chance of everything coming out firm.
Old 06-27-2003, 11:29 AM
Hans
Hans's Avatar
Post
Gratian
Check your mail box
TakeCare
Old 06-27-2003, 12:36 PM
IceShark
IceShark's Avatar
Post
Oh, one other thing DO NOT use Dot 5 Silicone based brake fluid. It will ruin your seals and then you will have real problems.
Old 06-29-2003, 05:47 AM
gratian
gratian's Avatar
Post
Thanks, guys.
Old 06-30-2003, 09:20 AM
MHT
MHT's Avatar
Post
be careful bleeding with a friend, I have seen cases where the pedal was depressed all the way while bleeding and crud built up in the master cyl. damaged the seals as they were pushed past it. This resulted in a car with clean fluid and no brakes at all. Under normal conditions the pedal is pushed nowhere near the floor, so with a vehicle where maintenance has been spotty, there is a chance of corrosion and so on building up in the bore of the master cyl. This will not apply to clutch hyd. systems of course. If you have a vacuum pump you could try sucking the fluid through the system, or you could just open the bleeder screws and let gravity do the work.
Quick Reply: brake fluid change
