Late engine,harness and ecu into early euro-few wiring q's
Does the DME switch the AC compressor on? The early cars have a dedicated switch so I wasn't sure how to connect.
Does the ecu handle the idle control when the AC is on via its own sensing of load? The early has a separate solenoid that adds air when the AC is on.
I did not get the altitude compensation box, should I find one or is this a minor issue?
I plan to swap over all wiring, ecu, engine as a system and these seem to be the only incompatibilities.
