968 ring & pinion problem on factory LSD trannys?
Are the famous 968 ring and pinion problem equally common on both the standard 6 speed and the LSD 6 speed or are there any differences in ring and pinion break down statistics?
Eirik Kvello-Aune
<a href="http://www.diateam.no/porsche" target="_blank">www.diateam.no/porsche</a>
Eirik Kvello-Aune
I think that if you go over to <a href="http://www.968.net" target="_blank">www.968.net</a> and follow the links to Martin's page on the pinion bearing problem, you'll find that it's equally distributed on all 6-speeds of both types, for all year models. But I may be misremembering this....
Jim, "Getrag, where our motto is 'Torqued way too tight is torqued just right!'"
