Pop-up problem... :(
Hey guys i have a 83 944 and the headlight when i turn them on they dont go up however if i assist the lights up they go and stay up when i turn the switch off the go down w/o a problem this happends everytime.... anyone ever experience this?
The 2 causes I have seen in the past are 1) the relay is going bad or 2) and most common is the armature inside the motor is wearing out and not making contact.You can open the motor up and check this but be careful not to lose any parts and remember where all the pieces go!
www.944online.com
jamie@944online.com
www.944online.com
jamie@944online.com
ok cool ill take a look at it tomorow also all of the sudden my battery is DEAD.... i think this car still have the OEM battery..... still have the screw caps on it.
Also, check the to see if the pins are still connected to the mail side of the connector at the motor. They corrode and cause weak/no perform situations.
