whoops...wrong power steering fluid
I used import power steering fluid (not ATF). Its freaking cold outside and dont really want to drain and replace (if its not an issue). Will this have adverse/detrimental effects on anything? It seems to turn smoother/easier now. Thanks.
BO
BO
PS fluid will eat the seals inside the rack and the pump,so drain or not to drain,$$$$$ for a pump and rack or five bucks foe the correct fluid. Drain it!
jamie@944online.com
www.944online.com
jamie@944online.com
www.944online.com
I have read that while ATF is the spec that regular mineral power steering fluid is not harmful. It might not have the seal-preserving additives and the detergents that ATF has but it is not going to damage anything by itself. I would not freak out, personally, but it would make sense to suck the old fluid out of the res a few times and replace with ATF one day soon. I would suggest doing this with the fluid nice and hot so any crud is well-suspended in the fluid. A cheap suction gun or even a turkey baster would work fine.
-Joel.
-Joel.
-Joel.
-Joel.
BO
Pulling the hose off the pump from down below is better/more thorough. I guess I'll get a quart of ATF over the weekend. I think the last time I bought ATF was for my 1976 Torino!
no need,
1> jack up car
2> undo banjo joint/clip/connection
3> drain
a piece of pi$$
1> jack up car
3> drain
a piece of pi$$
-Joel.
-Joel.
