Vibrations at idle - balance belt issue?
Hi there,
Quick question... recently I've been getting a lot more vibrations at idle than I used to. Actually, this has only started happening now that the weather is cold and mostly goes away when the engine warms up properly...
Is there anything I need to be doing about it or is it normal (or could it imply I need to retention the balance belt by any chance?)
Many thanks,
Alex
Many thanks,
Alex
Great - thanks a lot Maki (Greek by any chance?)
Any ideas or tips for:
a) figuring out if the engine is having trouble when cold
b) doing something about it?
Thanks,
Alex
Thanks,
Alex
Alex, you are right I am greek.
Now for the engine trouble I would expect if there is a problem it is likely a misfiring issue when cold caused by faulty ignition and/or fueling. A misfire will cause the engine to rock more then usual thus giving the impression the mounts are shot.
I would check condition of leads, plugs.
Depending on which 944 you have you may have problems with fueling mixture when cold. Not familiar with early 944 as I have an S2 though. S2 fueling problems when cold usually only caused by faulty coolant temperature sensor. Fueling is then controlled entirely by ECU.
In general if you have a cold fueling problem the car will also be difficult to start.
You can find how to check balance shaft alignment and motor mounts and lot more at following link
http://www.clarks-garage.com/shop-ma...ure-index3.htm
+1 on motor mounts
+1 on motor mounts
Its idling at one notch under 1000 (which is 800 from memory).
Not sure what you mean by a cold start system to be honest... its an 86 turbo... I'm not aware of anything specifically for cold starting.
Thanks!
Alex
Thanks!
Alex
There is a water temp sensor that send info to the DME,if faulty during cold weather it sends incorrect info to thr DME causing misfiring and rough idle.
jamie@944online.com
jamie@944online.com
Makis, allow me to disagree. I have anecdotal evidence from this weekend that mis-aligned shafts can make the engine feel like it wants to jump out of the car. The 924 I picked up last week ran terribly at idle. The previous owner thought it was an ignition issue, changed everything out, then gave up. I popped off the covers, aligned the shafts and the car runs like butter.
Team Owner
I Think I may know ths solution to both. oOn my 944 I had similar vibration at 2-3k , extremely bad. This was because the moron that worked on it had one of the shafts out 180 degrees causing the 2-3k vibration which is quite common.
If the shafts were out at different degrees ( not necesarily 180 degrees ) will casue vibration at diffferent rev ranges including idle.
Hmm... interesting points. The issue of course only started when the weather got cold and only at idle without anyone messing around with anything in between...
Is there an easy way to check whether vacuum leaks have something to do with this?
Thanks!
Alex
Thanks!
Alex
