mixture adjust
Old 12-22-2002 | 09:17 PM
LR45's Avatar
LR45
Post mixture adjust
When adjusting the mixture control (the hex head adjuster)on the air flow meter, do you turn it clockwise to increase,or counter clockwise to increase
86 944 N/A
Old 12-23-2002 | 08:58 AM
david fracolli's Avatar
david fracolli
Post
Clockwise = richer
Counterclockwise = leaner
Old 12-23-2002 | 01:39 PM
tdatk944+S4's Avatar
tdatk944+S4
Post
[quote] Clockwise = richer
Counterclockwise = leaner <hr></blockquote>
As in richer fuel or air?
Euros discribe their mix backwards from US.
Richer in US is air and IMHO Euro richer is fuel.
Any takers?
Tim
Old 12-23-2002 | 01:46 PM
Bryan's Avatar
Bryan
Post
Richer=more fuel.
Think of it this way. The further the flapper door in the air flow meter moves, the more fuel it tells the computer to inject. The adjuster is a screw that blocks off an air passage around the flapper door. Therefore, if you unscrew the adjuster, you are letting air bypass the flapper door. So it swings closed slightly, leaning the mixture. Screwing in the adjuster shuts the bypass forcing more air to go past the flapper door, opening it more. And enriching the mixture.
Bryan
Old 12-23-2002 | 05:47 PM
daly944's Avatar
daly944
Post
are we talking about that big black dial with the notches in it and the number 500 over and over, or something else? i opened up my afm top and i see that big black dial, is that what i use to adjust richness?
Quick Reply: mixture adjust
