time to tackle a few lighting problems- tail lights first
Almost Addicted
My tail lights don't work. I'm getting no power at the coupling right next to the light cluster. I know it isn't a ground problem, because it works when I apply external power. Yes, I've checked the fuses. The brake lights work, but the reverse lights don't. Any suggestions? I'm about one more night of looking at this from just running new wire from the fuse box.
Almost Addicted
Almost Addicted
Disconnect the wires from the reverse switch. One wire should be a +12v feed, the other goes right to the reverse lights. If you have +12v there, jumper the wires and your reverse lights should illuminate. If they do, then replace your switch.
Just hope it's something that simple. I just got done with rebuilding my interior harness and it was a PITA.
Almost Addicted
