LED Gauge Lighting Update **** SOLD OUT*****
Id also be interested,but let us know the replacement procedure.Thanks! <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" /> <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" /> <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Ok, lots of questions.
1st, this is for the LATE dashes only. I hope to have a solution for the early ones later.
2nd, you do not need to remove the steering wheel to take care of this mod. Mine is an airbag car, so I know this can be done.
3rd, I will have overly detailed instructions with photos.
4th, the install will take about an hour.
5th, plug and play: Remove gauge cluster from car, remove old reflectors from mounts, set my reflectors in place with adhesive, plug connector into bulb holder and position correctly, install gauge cluster in car and enjoy.
Again, this is a 100% reversable modification. You ruin nothing in the process. (so if you sell the car, you can put the reflectors in your new one)
I will get some new photos out to you guys ASAP. This week is busy as hell for me, so pics may have to wait until this weekend.
I guess I'll forever be longing for a dash light upgrade! When you do start in on the early dashes - let me know; you've got at least one order from me!
Good luck!
Good luck!
I'm telling you Perry -- white gauges with true u/v leds!! By the way...how powerful are each of your whites? I'm using 1100s for my key upgrades. I've got some battery-eating 7300s on order though!
ArcticCzar:
you are doing a key upgrade with LED's? what leds are you using? i was trying to do the same thing, but i couldn't find any that worked off 1.5V... or did you find a 3V battery that fits the key, too?
I could not find any UV LED's when I looked before. If you know a source, let me know. They must be 5mm or less.
I am using 2500mcd 20 degree lamps.
I've got some u/vs (well, they're being sent) that are actually fairly strong. I believe they're rated around 420 or so, which I believe will be too much; I'm afraid they will be too "purple" and wash out any u/v effects. I'll take a picture tonight of my key upgrade and post it. FIFTEEN 2500s?!? Jeez, I've seen lighthouses with less power than that!
That is why I went to 9. Any less and I cannot get even light. A 45 degree 1100 would be great, but I cannot get them in the 3-5mm range.
Thinking outside da' bun...
OK. Im taking your word on the instructions and plug and play. I can turn a screwdriver and read so I should be okay.
Im in.
Im in.
