924 Starting Problem
Old Oct 23, 2008 | 03:56 PM
stenakt's Avatar
stenakt
Default 924 Starting Problem
My friends 924 had a starting problem today. We quickly established there was no spark due there being no power to the coil (the +ive side of the coil was dead). I connected a wire direct from the battery to the coil and bingo! it started.
However, the problem then went away i.e. it would start without my hotwire. Any ideas? Some thoughts I had:
Is the ignition circuit controlled by a relay or is it direct from the ignition switch?
Does the standard 924 have some sort of security cut-off?
Your edification gratefully received.
Old Oct 23, 2008 | 04:14 PM
Airflite40's Avatar
Airflite40
Official Rennlist
Borat Impersonator
is it a 924 or 924S?? if 924 best seek help over at 924board.org
Old Oct 23, 2008 | 05:12 PM
924RACR's Avatar
924RACR
Yes, I'd be suspicious of the ignition switch - not an uncommon failure mode.
