Vendor Review: Ground Control
The average rule is 100-150# more spring in the rear. That's it. It is a pretty simple baseline to start from. Please note - that involves removal of the torsion bars.
My choice is 500# front & 600# rear to start.
C.
C.
I am running 500f and 650r no torsion bars and it is a very good setup for the track. Those are coupled with weltmeister front and rear sways.
My question is, the 250# fronts doesn't seem like much at all?? I have 250# welts and they don't seem stiff at all? I was thinking 400-500 on the fronts and 500-650 on the rears was where I wasa gonna go.
When I get around to doing my ft susp. 400 will be the lowest I will go. I talked to a bunch of the Cup guys racing at 944Fest this year and some of them still scrape the ft end with 600# springs on hard corners at the track. 250# is a tiny jump over stock it does not seem worth it. 350-400# FTW.
C.
Chad, i was talking about the Fronts, hence the.... "When I get around to doing my ft susp" Just clarifying. Was in response to flosho's post above mine.
Or are you rec. 450 for my rears with 400 fts? U lost me. LOL.
Jason at Paragon suggested to me a while ago that a good rule to start with is a 100-150# increase in the rear spring (if you are losing the T-bars).
C.
