968 LSD transmission oil
What transmission oil are you guys using on your 968 gearboxes. I am aqquiring a 968 LSD trans and are planning to buy some good oil for it. Any recomandations?
Eirik Kvelo-Aune
<a href="http://www.diateam.no/porsche" target="_blank">www.diateam.no/porsche</a>
Eirik Kvelo-Aune
Oh no... not another "what gear oil to use" thread
Basically, use whatever you like because everyone will have their own favorite. I've had good luck with Red Line and would use their 75W90NS if the LSD is the Torsen. This will give you the best shifting. If this is a clutch type LSD, use the regular 75W90.
How do I identify what sort of LSD it is? The tranny is currently in transit, but I do have pictures that show the numbers typed onto it.
PS:
Tom, the 5-55 brake prop. valve was to agressive, while the 5-18 was way to mild. An adjustable valve solved that problem.
Eirik Kvello-Aune
PS:
Eirik Kvello-Aune
