FS: 944/968 parts
FS: 944/968 parts
I just sold my car this morning, so here are the extra parts I have left. Parts are new unless stated otherwise. Prices do not include shipping. I will also be open to reasonable counteroffers.
968 front struts and springs (used) $40
944 hatch (used); has hole for wiper, hatch seal has wear. $40
$199 starting on ebay
944/968 tools (used, sold as set only) – P9201 belt calibration tool, 2 flywheel locks (one genuine Porsche and one aftermarket), Balance shaft locking bar, Timing Belt Adjusting Tool (24mm), Balance Shaft Belt Gauge
sold as set $5 - Sold!
944/968 Mahle Oil filter
944/968 Mahle Fuel filter
3 oil drain plug gaskets
sold as set $40
Sunroof deflector hinge (left and right) part #477 871 635
Passenger side door pin with LED part# 94463713800
2 Central locking rods #94453751100
Sunroof gear 944 564 430 01
$30
Front brake retainer set 94435195201 (note: missing one cotter pin as it was used on the car that was sold. All other parts are present)
sold as set $20 - sold
AC Dryer #944 573 943 00
AC switch #959 613 137-00
Sold as set $60
Pelican Parts Front Engine Reseal kit #10-0507-099-M260
2 Cam tower gaskets
Distributor Rotor (Facet brand) #94460290601
Belt tensioner 944 105 631 04
Timing belt guard nut #999 084 092 02
3 Head bolt washers 944 104 229 00
5 camshaft bolts 999 510 022 08
Sold as set $10 - sold
Water pump kit #951 106 021
Thermostat Shim 900 234 160 00
Thermostat O ring 944 106 929 05
Thermostat O ring 944 106 155 00
Thermostat O ring 944 106 929 08
Thermostat C clip 900 042 025 01
Auxilary fan switch seal N 043 808 3
sold as set $40
$30
Sold as set $60
2 Cam tower gaskets
Thanks. I paid for the crossmember, so I will put it up for sale when I receive it.
I will definitely consider another Porsche or another car down the road when the parking situation gets better.
Updated prices and status. Tool set is now on ebay with a ridiculously low starting price. I want to get rid of all this stuff this month, so make an offer if you want it. No reasonable offer refused.
