Anyone change the head on their key
Sure, just open the head up as if you were replacing the light battery. Then you will see the little spring mechanism which locks the key in place. Get a small pick and compress everything back, and pull the metal key out of the head.
Oops there is a small piece on the end that you have to pull out before compressing the spring piece back. It just pops on and off. Just did it with my fingernails and a ball point pen.,
I just finished making my own key head. I made a couple of copies from Ace and Home Depot and traced the end of the key head onto my new copies with a thin sharpie. I got my makita wheel cutter and some clamps to clamp the key down onto a table with a couple of 2x4s and a vise grip for fine tuning. Here are the instructions for removing the key head.
This is how mine comes apart. Pop cover off using a small flat screwdriver on the side with the indentation.
Remove button and battery
Remove the very small piece of plastic to the outside of the spring. 1/8" sqaure
with great caution - Remove the spring and larger piece of plastic (be careful that spring can really fly)
Now the key is unlocked and will come off the head
Don't loose any pieces!
