85.5 heater vacuum line question
I need to hook up the 2 vacuum linest that go into the bulkhead for the heat. One of the lines supplies vaccum to the heater box from the brake booster, and the other one comes out from the heater box to the heater valve at the back of the motor.
My problem is that the PO did not have these hooked up and I don't know which is which.
If you are looking at the bulkhead from the engine bay, at the 2 fittings does the supply go to the fitting on the left?, or the one on the right?
Thanks,
Oscar
Thanks,
Oscar
vac. line and valve can be clearly seen here.. (blue)
I have another question; is this vac. valve suposed to leak or is mine faulty? if I try to make vacuum with my mouth, I can draw air trough it.. it would probobly close if more vacuum would be applied, but it would still leak..
