Turn Signal/High Beam Problem
Hey guys,
Well, I broke my turn signal switch when I had the dash out and now Im running into some problems.
I was driving during the day using manual signaling and not at night because the High Beams are stuck ON. I picked up a used switch, one that sure has seen better days and plugged it in today. Again, nothing works. Could this be a relay issue too?
Now, I replaced the relay for the turn signals. Nothing, all fuses are good and the switch seems to be working. Is there anything else I could have fried?
Okay,
It is not the switch. It can't be. I just tried three different ones and I have the problem.
The horn is fixed, because of the switch. But now, the high beams are still stuck on, and the turn signals do not work. Also, the flashers DO work.
First person to fix this gets 5$ via PayPal for a beer. Minors need not apply.
Ok this is for 85/2 and up..
G2= relay, G4 Flasher relay, G12 High beam relay
Check grey wire on turn signal switch for ground..pin 1
Front harness headlights white/yellow power right pin c21, white/green power left pin c31 for high beams ..obv 12v if always on now.
High beam relay G12 seems to be stuck allowing power to pass through to pins c21 and c31 but check for ground in the switch pin 1 gray wire first to see if it is grounded.
Turn signal relay G4 shares power on pin31 with G12 on pin 85
Replace relay viii it is above fuses 4 and 5 and second over from the left. It is the additional high beam relay used on some models. I think you already replaced the turn sig flasher relay which is above fuses 11 and 12.. This is for and 84/1
