What tire pressures should I be using?
Just want some confirmation please.
1986 944na running 225/50/15 F&R (street use only)
Manual says:
NA Tire: F&R 215/60/15 Pressure: F29 R36
Turbo Front: 205/55/16 Pressure: F36 Rear: 225/50VR16 Pressure: R36
I am presuming that I stick to the owners manual recommended F29 R36 even though I have larger than stock tires fitted.
Manual says:
I ran 35 pounds all around when I got new wheels/tires and noticed a decrease in overall front grip. The brakes would lock up a lot faster and the car was a lot more prone to understeer. I haven't got a chance to try a lower tire pressure yet but I think the car will grip a lot more.
As for tire pressure with 18s, you should be able to run what everyone else is running because as posted above, tire pressure isn't dependent on tire size.
