No heat, need suggestions
Old 09-19-2008, 10:43 PM
jsaindc
jsaindc's Avatar
The heater was out on my 87 and I started to track it down. Turns out it was as simple as a blown fuse. Did you check fuse yet?
Old 10-22-2008, 11:29 PM
plastex
plastex's Avatar
Ok, still no heat.
I have changed all the vacuum lines, I have bled the cooland, and still no heat. I just checked the control unit by rotating the heating **** while looking at the driver side footwell to see if the lever is moving, and it is. the front lever moves everytime that the heat **** is rotated.
Some more ideas?
Thanks,
Oscar
Akron, Ohio
Old 12-28-2011, 12:17 PM
odurandina
Team Owner
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
driving to Atlanta last night, i discovered i had no heat.
so i thought to myself. Q; when was the last time you checked the coolant dumbass ? (A; 37 k miles ago when i did the belts, H20 pump, etc)... notice the fans seem to come on often ? (A. yes) how really f ucking stupid can you be ? (A. is that a rhetorical question ?)....
i've filled the reservior twice.... about 1/3 gallon of coolant left in the bottle. i'll let you all know if i'm successful getting all the Porsche juice down the hatch before it doesn't want any more Porsche juice.
Quick Reply: No heat, need suggestions
