Upper Rear Balance shaft seal leaking should I fix?
So I just finally put my new head gasket on, torqued the head down, timed the cams, had already put the rear belt cover, and crank gear back on, and finally found my mystery oil leak-- from the rear seal on the upper shaft. Should I re-seal? I'd have to take the crank gear and rear belt cover off again right? What else?
Hey Man
If you can feel the plug at the rear of the BS housing move at all the seal between it and the housing has shrank. Many people just clean it up real well and apply a good layer of Loctite 574 or oil resistant Permatex sealant. I've found three engines so far that have that plug flopping around. Odd thing is they didn't all leak. The other option requires removing the entire BS assembly which is no fun with the engine in the car.
I was asking because the intake and everything is already off so the BS housing is totally exposed (except i put the crank gear and rear belt cover on), but tell me more about these sealants....where to buy, which one's best.
If that's the case, just replace the seal. It's a quick job, just a lot of bolts, no big deal...
Then I would change the o-ring if you have almost everything already off to remove the cover. Hondabond can be bought at any Honda dealer or permatex Ultra-Grey is pretty much the same thing that can be bought at any parts store.
574 will not work in an external environment like that, it only seals in an anaerobic environment. IE, between two mated surfaces. It will stay a liquid goo. Orange RTV on the other hand will work just fine as a temporary fix until you want to tear it all down and fix the correct way.
