HELP!!! 2.7l Cooling hose connection
I have an '89 n/a with the 2.7l engine. I am in the last stage of replacing t-belt, balance shaft belt, accessory belts, oil cooler seal, and etc... The water pump that I took out only had one connection, to the lower radiator hose. Due to this connection the hose coming from the expansion bottle was connected to a small aftermarket hose and into the radiator just above the lower hose outlet. I got a new pump that has a spot to hook up the hose from the bottle (or so I think...) I currently have a cap on that spot. If I make that connection I will be left with a spot on the radiator (which I could place a cap on) My question is how is this supposed to be connected???
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
The extra hook up on the water pump is for the turbo modle. It should be blocked off from the factory. I am not sure about the connection you are talking about on the radiator?
Lifetime Member
Lifetime Member
I don't remember a spot being caped on the water pump on my 89 944 na, but I do remember a cap on one of the radiator spots.
I wish I could go look for you but the car is at the mechanic.
Maybe this will help? (it says from 83-85 944)
![](https://www.pelicanparts.com/944/944_parts/944_83-85/pic4.jpg)
