2" spacer on my 85.5, what type?
I am looking at putting some wheels from my 928 that have the late offset on my 85.5. I have been told that I will need some 2" spacers.
My question is should I just get 2" spacers that bolt on to the hub and have the studs on the spacer?, or get the spacer w/o studs and just install longer studs on the car?
What is the advantage of each?
Thanks,
Oscar
Thanks,
Oscar
you'll need bolt-on spacers, don't settle for slip-on. Bolt on is only only way to go. Yes, they're more expensive, but they're a helluva lot safer.
And depending on the offset of the 928 wheels (i.e., assuming they're the same offset as '87 and later 944s), a 1" spacer is what you'll want.
