Wipers only work sometimes??
My wipers only work part of the time. One time they'll work fine, next time the won't work at all. Also they only work at one speed when they do work. Sometimes they will start working, if I have them turned on, if I hit a bump. Any ideas? Thanks
On the Radar
Did you find which one it is?
Look under you fuse box cover. There is diagram to show where the relays are located.
You could try sanding the contacts lightly just to remove any oxidation.
Just be careful. My wiper motor was similar. I thought it was in the off position. The wipers were not moving or making any sound. After about 20 minutes on the road I noticed a burning smell that would not go away and got worse. I flew home to find that the wiper motor was so hot that it had melted some plastic and charred a paper sticker of some sort. The problem was the motor was in one of the on positions...my car still smells like smoke. I got a new motor yesterday and I am putting it in tomorrow.
