Need to replace the "Oil Pressure Sender"...
09-09-2008 | 01:00 AM
...can it be done without removing anything? Getting some weird readings on the gauge, doesn't want to drop below 4bar as it should. When I rev it, the pressure seems to want to hang at 4-5 bar. Clark's states possible faulty sender. It's the original unit...for $40 and some time I thought it was worth while.
09-09-2008 | 01:09 AM
Quote:
Originally Posted by
Fluidplay
Yup. 5 minute job (once the car is up).
09-09-2008 | 01:38 AM
09-09-2008 | 01:16 PM
Well, you have to remove two wires and the sender itself.
09-09-2008 | 01:26 PM
Get a "crows foot" wrench to remove it. A HELLOFA lot easier then trying to get a regular wrench in there!!
09-09-2008 | 02:29 PM
You need a 15/16" or 24mm crows foot or a stubby wrench will work also but takes some effort to loosen an old stubborn sender with the stubby wrench.
09-09-2008 | 03:58 PM
That's what I said ^^^ Booby trap!
((Goonies quote))
09-09-2008 | 04:12 PM
Spidey944
((Goonies quote))
I figured posting the size wrench needed might help.
and....what?!? There's *****? Where?!!
09-13-2008 | 07:02 PM
Whereabouts is the sender unit... any pics?
09-13-2008 | 07:15 PM
Sender is the blue arrow, this is the oil filter housing on the passenger side of the engine, below the headers.
09-13-2008 | 07:20 PM
Wow.... You guys are quick around here! Thanks for the pic, makes it a lot easier for us noobs.
09-13-2008 | 07:26 PM
just try wiggling the wires first, i too had weird readings until i accidentally slapped the wires during post oil change clean-up.
i know what you all are thinking... i was surprised too.
