Clutch line?
Hi,
So i just changed the master and lave cylinders in my 84' 944 and while reataching the hydrolic pressure line (as i was told) the end snapped off (metal line was stuck and twisted until breaking). This is the line that comes form the slave cylinder and meets with the rubber end of the line coming from the mastercylinder for the clutch. I havent been able to find this part other than directly from porsche thru pelican parts but it is 87$$ and has no picture and is called clutch line. I was wondeirng if anyone else had this issue or knows a cheaper site to buy this part or at least can confirm the correct name its item #94442309100 on pelican parts. Also if anyone has one and is looking to get rid of it ill take it (not that its a common part to have lying around
TIA
TIA
