Engine swap '85 to '87
I lost my motor the other day to a double gasketed oil filter....RIP
I am looking for a new (used) motor to swap into my '85 944 NA. What other types of 944 motors will fit in there? How about an '87 944 NA? Would there need to be any major mods to get it to fit? What parts would not be compatible? How about the transaxle and the radiator? I've been looking around on the site (search) for info, but don't see much info on the early 944's. What engines should I be thinking about here with a constrained budget? Thanks for you advice guys!
So I finally got my replacement engine on order. I'm sure that it will take a while to get it shipped to me (Florida --> Colorado). The new motor is from an '83 so I'm hoping that everything will match up. The only thing I'm worried about is the power steering. I know that '83 didn't have power steering, so I'm wondering if I can use the power steering out of my '85. Do you know if it will work?
I've just about got the old motor out. I only need to remove the motor mounts, steering control arms, and the cross member. Hopefully the new motor will go right in.
Also, what types of things should I replace since I have the motor out (low dollar)? I am thinking about gaskets, seals, timing belt, etc. Do I need to order new gaskets for the exhaust? Any help would be welcomed. I'd like to be able to get the new motor in once it arrives without having to stop to await parts.
But if you're swapping, a front seal kit with a water pump/belts/rollers might be a good way to go. If you're already re-sealing, it shouldn't be a big deal if you have to swap the piece I'm talking about.
