Brighter Tailights
Old 08-30-2008, 02:17 AM
Will Feather
Will Feather's Avatar
Whoa! Lilredpo, you are freakishly close to me.
Old 09-02-2008, 11:25 AM
lilredpo
lilredpo's Avatar
If you ever need any help, please let me know. My knowledge is limited, but I can turn a wrench.
Old 09-07-2008, 07:52 AM
Toran
Toran's Avatar
Default Still looking for this little plastic socket
Still looking for this little plastic socket. Anyone know where to locate it or a replacement?
T.I.A.
Old 09-07-2008, 11:10 AM
Jim 944S
Jim 944S's Avatar
Volkswagen, IIRC...
Do a search "IceShark and "socket"... see if it comes up!
Jim 1987 944S
Old 09-07-2008, 11:23 AM
Jim 944S
Jim 944S's Avatar
Donald, I'm getting pretty good at customs forms and have now shipped stuff as far away as New Zealand and Australia so Canada is no problem. <img border="0" title="" alt="[Wink]" src="wink.gif" />
Robert, I want the reverse all red just from a style issue. I think a white rectangle doesn't look good. If anything I would have thin horizontal white stripes. But if these more powerful bulbs test out OK, I'll go solid red.
John, no problem. I'm doing all this stuff to my car so these bulbs will have to make the grade.
I took apart my rear lenses to add a socket and bulb for the dead lens cell that Porsche never lit up, the lower middle one. VW dealers sell the bulb socket for $3 each, sort of expensive for a 10 cent part but what can you do? The part number is 111-945-265 for those that want to do this.
Anyway, as I was looking at the bulbs, most had thin black tungsten deposits on the glass envelope. If you set them on a white sheet of paper you can see it. While the bulbs still work the deposits cut down on light output more than you would suspect. Probably 50%. So, I'm just going to replace all the #1156 and #97 bulbs.
If you folks want to do this also I can order a bunch of these bulbs. For the 1156's a major brand will probably cost about 75 cents while the asian ones would be about 26 cents. 97's would be about the same. I will go with a major but I wanted to let people know the prices on the asian bulbs you see in Pep Boys.
There it is!
Jim 1987 944S
Old 09-07-2008, 12:01 PM
Jfrahm
Jfrahm's Avatar
Have your taillights been tinted? The plastic looks a bit dark.
You can get rebased 50 watt halogen bulbs to fit, but I do not know if they would melt the plastic or overstress the wiring.
-Joel.
Old 09-07-2008, 12:11 PM
Toran
Toran's Avatar
Thanks for the VW part number 111-945-265
Old 09-07-2008, 12:36 PM
Bart
Bart's Avatar
You can buy a higher wattage lamp but be careful you don't get too high a wattage. It will melt the plastic surround.
Don't ask how I know this.
Old 09-07-2008, 12:45 PM
marcoturbo
marcoturbo's Avatar
What kind of wattage did you use before melting your lenses ?
I now run 35w bulbs for brake and reverse lights (Narva 796) and by now no problem noticed.
Old 09-07-2008, 12:53 PM
Wipeout
Not Special
Wipeout's Avatar
I believe that empty spot is a provision for Euro foglights...
Old 09-07-2008, 01:08 PM
Bart
Bart's Avatar
That's what I have. Came wired that way on mine.
I don't recall the wattage now. But I know I had to lower the wattage in the Euro foglight spots because the plastic was melting. They were BRIGHT!
Old 09-07-2008, 01:52 PM
Jim 944S
Jim 944S's Avatar
Iceshark seemed to feel that was the max safely possible.
Jim 1987 944S
Quick Reply: Brighter Tailights
