What size wrench to bleed brakes?
Just want to make sure I got the correct size wrench to open the bleeder on teh calipers before I take my wheels off.
Also anyone know how tight you have to torque the bleeder valve?
thanks.
thanks.
Almost Addicted
not very tight- you will be able to tell.
It might be 7mm, but I can't recall for sure- I do know I have to get out my set of tiny wrenches for it though.
thanks for the info I have both 7 / 11mm so shouldn't be problem, just thought it might be an offset wrench.
I just got my powerbleeder from paragon so hopefully this will be easy.
I changed mine out to 8mm speed bleeders. As I recall, the rears were 7mm and the fronts were 7 or 8mm.
ok another dumb question. Am I suppose to remove that little filter think inside the overflow tank before screwing on the power bleeder. It's a littel cup with a pinhole in it looks like it is there to prevent big piece falling into the tank.
do I take that out or leave it in?
