better gas mileage w/ straight pipe????
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
I've been testing my car's setup lately in regard to exhaust system on the car and found some interesting things. First of all, a recent smog inspection indicated i was running fairly lean on the factory setting of the AFM! <img border="0" title="" alt="[Eek!]" src="eek.gif" /> I turned it richer, replaced the spark plugs and the car ran better.
I decided to run straight pipe on my car and noticed that i can go longer on a single tank of gas than i did before! Of course I ran the cat on to see how many miles i can get out of new plugs and the richer AFM setting. My calculations are as follows...
W/ Straight Pipe: Approx. 248 miles
W/ Catalytic Convertor: 230 miles
NOTE: Both tests were performed until reserve light came on.
Of course I could be wrong but I am wondering if there are any European 944s on this board that run real good. BTW my car has 171,000 mi on it now if those figures look low, I could have a compression leak..
<img border="0" alt="[burnout]" title="" src="graemlins/burnout.gif" />
You MUST have something wrong. I'm regularly going 450 miles from fill-up to reserve light. Granted, my car has a bigger tank. Last time I did the numbers, I got 27 and change MPG.
You know i was getting 27MPG too. I was really amazed. I left from Hayward, Ca, to the bottom of the grapevine near L.A. before refeuling. I think I could have made it to magic mountain but didn't want to push it.
I'm getting a high flow cat and new muffler put on this week. This muffler will have a silencer.
I'm wondering how much louder your car is with a straight pipe?
I once had this muffler on my car.
<img src="http://www.sromagazine.com/article/products/exhausts/junk.jpg" alt=" - " />
If your bored you can read my review here. Kinda of funny reading something I wrote 5 years ago
<a href="http://www.sromagazine.com/article/products/exhausts/" target="_blank">http://www.sromagazine.com/article/products/exhausts/</a>
Fuse 24 Assassin
Fuse 24 Assassin
how loud is it??? Right now it's stupid loud because of my Dynomax straight thru. I'm thinking of going with a Flowmaster now since the perforated tube rattles when hot.
One difference is that the 84 944 has a much smaller gas tank than the later models.............
Someone may have the numbers, but from memory standard was 17gal on pre-oval cars and after 86 it was 21gal. On 85.5 models, I have seen both for some reason (I have a 21 gal).
Tifo
Tifo
I have been getting around 295 miles when the fuel light comes on and usually fill up at 310-330mi. I also do a lot of interstate driving though around 2800-3000 rpm. I am very interested in getting a Bursch header and cat-pipe, but I do not want it to be obnoxious. I get many compliments on the current setup w/ just a B&B catback. Anyone have or ever run a header/cat-pipe and B&B/SFR/GHL setup before on an NA? I think the screen that is placed in the entrance of the cat is clogged up, the rest of the 20 year-old cat has dissengrated itself into tiny black little muffler bearings. By stock muffler sounds like a mirracha!
Take Care All!
Take Care All!
I did an actual mileage driven to fuel used test a couple of months ago. My car is essentially stock, and it came in at 30.3 mpg, and that was mostly around town! That is also assuming that I indeed have a 21 gal tank. I think the mileage you actually get is highly dependent on how you drive your car. If you really stomp it like a sports car, naturally mpg goes down fairly quick. My driving is not overly aggressive, but I don't putt-putt either. Plus I use high test gas a low viscosity oil and new plugs. So, in the end, I imagine its a combination of a whole bunch of things, not just one in particular.
